Getting 401 when using Cognite API in postman
Can someone revert with proper procedure for using any of the cognite data fusion API using postman
Hi @VamsiGrandhi ,
I hope the above helped. I’m closing this topic now, please feel free to create a new post if you still experience problems.
  • 285 replies
  • October 12, 2023
@VamsiGrandhi Have you followed the links below?  Downloading the collection and setting up environments will come in very handy 😀.
Looking at your setup.  You need to to change your scope parameter to be https://{{cluster}}.cognitedata.com/user_impersonation
https://api-docs.cognite.com/20230101/#section/Postman
https://developer.cognite.com/dev/guides/postman/
-Jason
Andre Alves
Forum|alt.badge.img+13
Hi @VamsiGrandhi,
Please check with you are using client authentication as “Send as Basic Auth header”
See my token configuration below:
baseUrl: https://api.cognitedata.com
Auth Url:
https://login.microsoftonline.com/{{tenant-id}}/oauth2/v2.0/authorize
project: publicdata
Andre Alves
@VamsiGrandhi
Please let us know if it works for you, and we would appreciate it if you could share how you resolved it.
Thanks in advance
  • 223 replies
  • October 31, 2023
Hi @VamsiGrandhi, did the above help you?
  • November 9, 2023
Hi @VamsiGrandhi ,
