Which method Cognite PI Extractor is internally using to connect with OSIsoft PI Server? Is it using PI SDK or PI AF SDK or PI Web API?
  • September 27, 2023
  • 78 views
Hi Team,
We are working on the Cognite Pi Extractor to fetch the data from OSIsoft PI Data Archive. From the documentation we understood that we can use the OSIsoft PI Web API or PI SDK to retrieve the data we need from OSIsoft PI Server. But it is not specifically mentioned in Cognite PI Extractor's documentation that which method it is internally using. Is it using PI SDK or PI AF SDK or PI Web API?
Best answer by Carin Meems
Hi @Devi Iragavarapu Sri Sandhya, it is using the PI AF SDK. You can refer to the below post:
  • 223 replies
