Could not post nodes with Float properties if the value is 0 or negative
When adding a node instance with Float properties, it always gives an error “The value of property 'xxx' must be a 64 bit floating point number” if the value in the request body is 0 or negative number, but it works fine if the value is positive.
Could you help take a look?
Best answer by Anders Hafreager
The bug has been fixed and rolled out to all production clusters now.
Anders Hafreager
Seems like we introduced a regression here. Will work on a fix and update this post when it’s done.
Anders Hafreager
