DB extractor - storing incremental state for Timeseries query
  • January 24, 2023
  • 7 replies
  • 143 views
I am observing below error(in bold) in extractor log for timeseries query:
2023-01-24 03:31:03.345 UTC [INFO    ] QueryExecutor_0 - Starting extraction of avocet-timeseries
2023-01-24 03:31:03.345 UTC [DEBUG   ] QueryExecutor_0 - Query: 'SELECT ITEM_ID + PROPERTY_TYPE+'Avocet' as "externalId", START_DATETIME as timestamp, PROPERTY_VALUE as value FROM ITEM_PROPERTY1 WHERE START_DATETIME is not null and PROPERTY_VALUE is not null and LAST_UPDT_DATE is not null ORDER BY LAST_UPDT_DATE ASC'
2023-01-24 03:31:03.612 UTC [INFO    ] QueryExecutor_0 - No more rows for avocet-timeseries. 2 rows extracted in 0.267 seconds
2023-01-24 03:31:03.873 UTC [DEBUG   ] ThreadPoolExecutor-9_0 - https://westeurope-1.cognitedata.com:443 "POST /api/v1/projects/slb-pdf/timeseries/data HTTP/1.1" 200 22
2023-01-24 03:31:03.875 UTC [DEBUG   ] ThreadPoolExecutor-9_0 - HTTP/1.1 POST https://westeurope-1.cognitedata.com/api/v1/projects/slb-pdf/timeseries/data 200
2023-01-24 03:31:03.877 UTC [INFO    ] QueryExecutor_0 - Uploaded 2 datapoints
2023-01-24 03:31:03.878 UTC [ERROR   ] QueryExecutor_0 - Can't store state for avocet-timeseries, LAST_UPDT_DATE is NULL/not present
2023-01-24 03:31:03.880 UTC [ERROR   ] QueryExecutor_0 - Error in extraction of avocet-timeseries: 'Missing incremental_field'
2023-01-24 03:31:03.881 UTC [INFO    ] QueryExecutor_0 - Closing ODBC connection to sqldb for avocet-timeseries
The query section in the configuration is as below:
  query:
    SELECT
      ITEM_ID + PROPERTY_TYPE as "externalId",
    FROM
      ITEM_PROPERTY1
    WHERE
      START_DATETIME is not null and PROPERTY_VALUE is not null and LAST_UPDT_DATE is not null and LAST_UPDT_DATE >= CAST('{start_at}' AS DATETIME2)
    ORDER BY
      LAST_UPDT_DATE ASC
  incremental-field: LAST_UPDT_DATE
  schedule: "*/1 * * * *"
  initial-start: '2020-01-01'
  destination-type: TIME_SERIES
If we use the raw queries, the state is being maintained properly but for timeseries query I am facing this issue.
Can you please take a look and provide the recommendations?
Best answer by Pierre Pernot
I would try something like that:
(I assume you are using SQL Server, am I correct ?)
- name: timeseries
  database: sqldb # same as above database
  query:
    SELECT * FROM (
      SELECT
        ID + TYPE as "externalId",
        CAST(LAST_UPDT_DATE as timestamp) as timestamp,
      FROM
        ITEM_TABLE
      WHERE
    WHERE {incremental_field} is not null and {incremental_field} >= {start_at}
    ORDER BY
      {incremental_field} ASC
  incremental-field: timestamp
  initial-start: 1577836800000
If that does not work, please let us know and send us both the query and the logs, so we can help you debug.
Also, I don’t know what your LAST_UPDT_DATE column looks like, you might have to adjust the CAST statements.
Pierre  Pernot
  • 15 replies
  • January 24, 2023
Can you try to add “LAST_UPDT_DATE” inside of the SELECT statement ? Please let us know if that works better.
Thanks Pierre for your reply. Instead of START_DATETIME I used LAST_UPDT_DATE for timestamp in select but I still see the same error.
Pierre  Pernot
  • 15 replies
  • January 26, 2023
could you please share your whole query parameter ? including the incremental field ?
The actual timestamp is present in the column  START_DATETIME but as you mentioned above I modified it to LAST_UPDT_DATE in select query.
Here is the query section in config:
  query:
    SELECT
      LAST_UPDT_DATE as timestamp,
    FROM
      ITEM_TABLE
    WHERE
    ORDER BY
      LAST_UPDT_DATE ASC
Pierre  Pernot
  • 15 replies
  • January 27, 2023
- name: timeseries
  query:
    SELECT * FROM (
      SELECT
      FROM
        ITEM_TABLE
      WHERE
    ORDER BY
In our case LAST_UPDT_DATE column(incremental column) and START_DATETIME(actual physical timestamp of property) both are different. Looks like , the above query assumes both are same.
so below query works assuming both are same:
    SELECT * FROM (
      SELECT
        ITEM_ID + PROPERTY_TYPE+'Avocet5050' as "externalId",
        CAST(LAST_UPDT_DATE AS DATETIME) as timestamp,
      FROM
        ITEM_PROPERTY
      WHERE
    ) as table1
    WHERE table1.{incremental_field} is not null and table1.{incremental_field} >= {start_at}
    ORDER BY
      table1.{incremental_field} ASC
What changes are required considering START_DATETIME as actual physical timestamp of measurement and LAST_UPDT_DATE as a incremental field(when that measurement got updated in database table).
Looks like, The extractor has minimum accepted date so that’s why there is an issue in storing incremental state
Checked with below dates:
1971-01-01 05:29:59.000,  Error in logs: Discarding 1 datapoints due to bad timestamp or value
1971-01-01 05:30:00.000,  No Errors
so looks like it works when timestamp is >= 1971-01-01 05:30:00.000 (UTC+5.30 timezone).
If extractor considers the source timestamp in UTC timezone , then it could have worked beyond 1971-01-01 00:00:01.000.  Does it mean that extractor considers source timezone?
