Charts Events - Basic Improvement Recommendations
  • December 13, 2022
  • 63 views
Cognite Team - thank you for bringing back the ability to overlay events directly on the chart as was previously a capability in ADI. It’s a welcome return and valuable add to the application.
After utilizing the app a bit, I have a couple of “low hanging fruit” recommendations:
  • Can we add the event description to the metadata that’s shown on the event?
  • Is there a way to toggle using both start time and end time vs. just using start time? Some of the events that we have run for months and the start time is really the only relevant point for the trend
Here are some more complex recommendations:
  • Since charts is now integrated directly in Data Explorer - is there a way to click on the event results and actually go to the event directly in CDF to look at all the metadata?
  • When filtering for events by selecting the asset - is there a way to toggle “select all children” as well? An example is that we have several pumps where work is tagged to the smallest component, but if we filter the events to the skid we do not see any of the work orders unless we select all the children
Thanks again and glad to see the direction CDF / Charts is moving
Knut Vidvei
  • 132 replies
  • December 13, 2022
Hi, Richard!
Thank you for the valuable feedback. We are very happy to have this in Cognite Data Fusion, and will continue to evolve it based on user feedback.
Let us get back to you on your suggestions, and continue to post your thoughts here if you discover more.
Knut
Aleksandra Knodlseder
Adding my 3 cents to this topic. It would be great to be able to filter on the WO types, like:
PM01 - Breakdown Maintenance
PM02 - Regular Maintenance
PM03 - Preventive Maintenance
The use case would be: show me the trend of a parameter or set of parameters after the corrective maintenance (PM01) event. This could help to isolate the equipment behavior prior to a failure and label the data showing symptoms of the failure/FM.
thanks,
Aleksandra
  • 15 replies
  • December 14, 2022
Aleksandra Knödlseder wrote:
thanks,
Aleksandra
Aleksandra - you should already have that capability (at least if those fields are a type or subtype). For us we have work order type as a subtype in CDF
