FDM - Querying using multiple filters
  • November 25, 2022
  • 140 views
Hello All,
I am trying to query the FDM schema after populating (listForecast in slb-pdf project). But i am getting the error! seems like an bug. Can you check if I am doing something wrong.
query MyQuery {
  listForecast(filter: {oilRate: {eq: 1.5}, and: {gasRate: {eq: 1.5}}}) {
    edges {
      node {
        id
Error I am getting is as below. Can you help if known bug or if I should do differently?
 "message": "Expected either 'and', 'or', 'not' or a single field condition used in the same filter block.",
Best answer by Vu Hai Nguyen
Your query syntax is not correct. I think if you want the and condition on both oil Rate and gasRate it should be:
filter: { and: [{oilRate: {eq: 1.5}}, {gasRate:{eq:1.5}}]}
  • 21 replies
  • November 25, 2022
Thanks Vu Hai Nguyen, I was using the UI to built the query but did not worked somehow.
Thanks for your input, it works!
David Liu
  • 15 replies
  • November 25, 2022
We are working on making the filter builder to be more robust to capture this ability to build “list” of `and` and `or` filters :) Hope the workaround in code will work in the mean time!
