Cognite Function deployement failed - 'Process-13 terminated unexpectedly with exit code 1 while running job.'
  • August 10, 2022
  • 48 views
we are facing issue while deploying the function
Message: Function deployment failed.
Trace:
('Process-13 terminated unexpectedly with exit code 1 while running job.', 1)
Traceback (most recent call last):
File "/app/.venv/lib/python3.7/site-packages/cognite/processpool/processpool.py", line 81, in result
ret, err = pickle.loads(self.recv_q.get(block=False))
File "/usr/local/lib/python3.7/multiprocessing/queues.py", line 107, in get
raise Empty
_queue.Empty
During handling of the above exception, another exception occurred:
File "/app/.venv/lib/python3.7/site-packages/cognite/processpool/processpool.py", line 163, in _job_manager_thread
result = worker.result()
File "/app/.venv/lib/python3.7/site-packages/cognite/processpool/processpool.py", line 91, in result
self.process.exitcode,
cognite.processpool.processpool.WorkerDiedException: ('Process-13 terminated unexpectedly with exit code 1 while running job.', 1)
Best answer by Ana Villarreal
Hi Kumar,
Thank you for using Cognite Hub! We’ve created a ticket and forward it to the support team, you will be notified by email with the ticket information. If you would like to report any issues/bugs you can also do it by sending an email to support@cognite.com our 24/7 support team will be able to help you.
Have a nice day.
Ana
  • 10 replies
  • August 11, 2022
Hi Kumar,
Have a nice day.
Ana
