We are using cdf toolkit to deploy our container, views and data models.
We recently added many new views, these views are dependent. i.e: they reference each other in the properties through a source block or via implements block. Here an examples of these view dependencies:
- externalId: View1
implements: []
properties:
test:
container:
externalId: Container1
space: some_space
type: container
containerPropertyIdentifier: Test
source:
externalId: View2
space: some_space
type: view
version: v1
space: some_space
version: v1
- externalId: View2
implements: []
properties:
wow:
container:
externalId: Container2
space: some_space
type: container
space: some_space
version: v1
or
- externalId: Country
implements:
- externalId: CountryAttributes
space: '{{sp_dm_dap_knowledge_graph}}_wv'
type: view
version: '{{dap_version}}'
properties:
Wells:
connectionType: multi_reverse_direct_relation
source:
externalId: Well
type: view
through:
identifier: Country
source:
externalId: Well
type: view
implements: []
properties:
CountryName:
container:
externalId: Country
space: '{{sp_dm_dap_knowledge_graph}}'
type: container
containerPropertyIdentifier: CountryName
RegionalEntity:
container:
externalId: Country
type: container
containerPropertyIdentifier: RegionalEntity
We have these errors:
ERROR (ResourceCreationError): Failed to create resource(s). Error: Cannot upsert view 'sp_dm_dap_knowledge_graph_wv:Country/0.0.28'. Implemented view 'sp_dm_dap_knowledge_graph_wv:CountryAttributes/0.0.28' does not exist. | code: 400 | X-Request-ID: 027470c1-3679-9e04-a540-68ab60d31be8 | cluster: westeurope-1
The API Failed to process some items.
Successful (2xx): []
Unknown (5xx): []
Failed (4xx):
IMHO, this is issue in CDF toolkit dependencies resolutions. How CDF toolkit does this? How to avoid this errors?
Thank you
