[Data Scientist Basics] Cognite Charts Hands-on missing time series data
For the Data Scientist Basics: Cognite Charts Hands-on Data quality use case, the time series exist, but do not seem to have any associated data points (TIT202-21, TIT201-20), so I am unable to fully test this use case.
Also, for the Valve mileage use case, I believe the time series (VAL_23_ZT_92543:Z.X) data looks different than what the example solution shows (and it doesn’t show up the same way on the PDF document - there is no link for that location on the PDF). Is this correct or did I possibly do something wrong?
Best answer by Sofie Haug
Hi @Caroline M Fox
I see that TIT202-21 and TIT201-20 has datapoints but you would need to change the timeframe (go a bit back in time), if it should be like this? I’m not sure and will investigate with my colleagues!
For the Valve mileage use case, the data will look a bit different due to variations in the data.
I hope you got the answers needed to complete the training! I’ll update you if I find something on the TIT202-21/TIT201-20 time series! In the meantime, happy learning!
Sofie Haug
Forum|alt.badge.img+7
  • Cognite Academy Instructor
  • 151 replies
  • July 29, 2024
Hi @Caroline M Fox
  • August 30, 2024
Hi @Caroline M Fox,
Isha Thapliyal
  • 214 replies
  • September 19, 2024
Hi @Caroline M Fox ,
Did the above help resolve the issue?
Please let us know if the issue has been resolved so i can move ahead with closing this topic for now.
Thanks
Isha
