asset-timeseries mapping issue
Forum|alt.badge.img+5
I have a dataset which consists of Assets.
and another dataset which consists of timeseries.
I wanted to map assets to timeseries
But ,i am getting access issues.
FYI.
We have been given all required access (i.e. read and write).
Query:
WITH assets AS (
    SELECT  id,name
    FROM _cdf.assets
    where dataSetId = dataset_id("test_assets")
tagname AS (
  select tagname as tagname,
  name as assetName
  FROM `test_assets`.assets
time_series AS (
    SELECT name, externalId
    FROM _cdf.timeseries
  where dataSetId = dataset_id("test_timeseries")
SELECT  ts.name, a.id AS assetId
FROM tagname t
INNER JOIN assets a ON a.name=t.assetName
INNER JOIN time_series ts ON ARRAY_CONTAINS(t.tagname, (REPLACE(SUBSTRING(ts.externalId FROM 14), '.Value', '')))
Thanks in Advance.
Please give suggestion for above issue
Hi @Sumedh Vaidya,
After adding the necessary access to the user account, I trust that the issue has been successfully resolved.
Hi @Sumedh Vaidya,
I have created a support ticket, so our team can follow up and help you.
Hi @Sumedh Vaidya,
