setting parentExternaliD as an empty string, "" and not as NULL
  • May 2, 2024
  • 26 views
Forum|alt.badge.img+4
Busy with training module:
Data Engineer Basics - Transform and Contextualize > CDF Transformations > Assets transformation
I have the following SQL:
The Preview works:
But, doing Run, leads to an error.
So, of course the NULL in the 1st row above ought to be   “ “ for the root asset.
Q1. How do I test for NULL and set NULL value to “ ” in the Spark SQL query?
Thank you!
Doug
Best answer by Sofie Haug
Hi @Mugless Durry
you can use a IF statement, like:
IF(parent_loc_id='' OR parent_loc_id IS NULL, '', parent_loc_id) AS parentExternalId,
Sofie Haug
Forum|alt.badge.img+7
  • Cognite Academy Instructor
  • 161 replies
  • May 2, 2024
Hi @Mugless Durry
