After Postman authentication, accessing CDF data in Postman is denied
  • April 26, 2024
  • 45 views
Forum|alt.badge.img+4
This post is pursuant to “Postman does not work properly after authorization”.
I have begun the module:
Followed the steps in the instructions.
Environment variables:
Authorization was updated:
Then, to test, I went:  Cognite API collection > "Assets" folder > "List assets" > Send
This gives Error - different to that in post “Postman does not work properly after authorization” -
Next, I try to list the timeseries data: timeseries > list time series > Send. Whereas in post “Postman does not work properly after authorization”, I got back data, now I get
Q1. Please could someone help me get around this?
Thank you for your support.
Doug
@Mugless Durry can you please change the configuration as below and check again. Also make sure to replace the environmental variable baseURL to baseUrl
Forum|alt.badge.img+8
