Data Engineer Basics Hands-On CREATE Access Rights Issue
I’m facing following error while creating an asset in Hands-On:
CogniteAPIError: Resource not found. This may also be due to insufficient access rights. | code: 403 | X-Request-ID: d75b2c0d-f96b-9efc-8dbc-6aef50e25dff The API Failed to process some items.
But able to read data and create a dataset.
Please kindly advise.
Asan
Best answer by Asan Arifov
Hi @Dilini Fernando,
Yes. The issue were resolved by setting write_protected=False
Thank you @Sofie Haug.
Sofie Haug
Forum|alt.badge.img+7
  • Cognite Academy Instructor
  • 151 replies
  • April 25, 2023
Hi @Asan Arifov
Are you able to do a list assets call?
Sofie Haug
  • 151 replies
  • April 25, 2023
Hi @Asan Arifov
Which course are you working on? You could also send us the url from learn.cognite.com
  • 5 replies
  • April 27, 2023
Hi @Sofie Haug,
It is Learn to Use the Cognite Python SDK course, Solving the hands-on task.
I figured out the root cause of the issue.
In step 1 it advises to set write_protected=True, but it makes impossible to add an asset to the data set later in step 2.
Sofie Haug
  • 151 replies
  • May 3, 2023
@Asan Arifov Thank you for your feedback! I’ll look into that
Sofie Haug
  • 151 replies
  • May 15, 2023
@Asan Arifov  I didn’t get this issue myself. But if you still do, please create a data set that is not write protected.
Hi @Asan Arifov ,
I hope Sofie’s reply was helpful. Did you manage to solve this issue?
  • 5 replies
  • June 8, 2023
Have the same issue. Dataset’s write_protected  is False, but I still get Resource not found error.
@Maksim Ziniakin will you be able to share your code and the CDF project that you are working on? Please remove any sensitive information in the code.
