Entity Matching data set not available
Data set is not available in the below path for the practice, kindly request your support to resolve this ASAP.
Naveen
Best answer by Carin Meems
Hi @Naveen V,
Thank you for reporting this, this is a known issue. Unfortunately for now you’ll have to skip this part, or create your data set from scratch and try again.
I’ve created a Support ticket for you, via which we will follow up with you on the progress of fixing this problem.
Have a good week!
Carin
  • Active
  • January 9, 2023
Naveen
Data set ID is NV1991
  • January 9, 2023
Hi @Naveen V,
Have a good week!
Carin
