Global companies might face the challenge of having global data used by different countries, regions and languages, in ERP and other source systems. Such data exist in form of shared ‘catalogs’, ‘master data’ or ‘configurations’. This data is often setup and maintained in source systems, with different languages to support users in multiple regions. This data then became attributes or metadata in Cognite objects.
Example given - Current situation:
This 'catalog' data (metadata) is extracted from source system in one single language - English - only, since CDF can't store it in multiple languages.
Then these metadata - field names and field values - are displayed in CDF with the only one language available - English -.
*Notice Metadata fields names and metadata field values don't change, despite user changing CDF language settings.
Proposed solution (request):
Have a way to store metadata fields names and metadata field values, coming in different languages from source systems, with language indicators such as EN (English), SP (Spanish) or DE (Deutsch) in CDF.
Then display the metadata field names and metadata field values in CDF UI, based on the user language settings.
