Unable to login to cdf tenant
  • September 5, 2022
  • 6 replies
  • 91 views
Divyanshi Mangal
Active
When I try to access cdf tenant URL (https://slb.fusion.cognite.com/), I get this error.
I have been trying to figure this out but nothing so far, kindly suggest where to get these permissions from.
Best answer by Maneshka Paiva
Hi Divyanshi,
You will need to contact your Azure Active Directory administrator to add you to the required groups. Once you are added you should be able to access CDF.
Maneshka
Hi Divyanshi,
Maneshka
@Divyanshi Mangal I have added your user to the AAD Tenant for the appropriate CDF projects.
Divyanshi Mangal
Active
Thanks @Jason Dressel . This helps!
Hi @Jason Dressel, could you please add the following users to the AAD tenant for the appropriate cdf projects?
mgandhi3@slb.com
spulikonda@slb.com
gbhosale2@slb.com
we are getting the same error as Divyanshi while accessing the cognite tenant url (Cognite Data Fusion)
Users have been added!
Thanks @Jason Dressel !
