When using Data Explorer, if you click on an Asset, that branch will expand, and others will minimize. Sometimes I want to be able to switch between similar Assets that are in different hierarchies (Example being two different lines in a plant, or two different facilities). The current behavior is that if you click on an Asset all other asset trees will be minimized. Even if you manually expanded other hierarchies/trees, clicking an asset will reset the view.
Would be nice to either have an option (checkbox) to auto-minimize or change this default behavior.
Example Tree:
- Plant 1:
- Tank1
- Mixer1
- Press
- Plant 2:
- Press
- Mixer
- Oven
- Tank
If I were to click on Plant1>Tank1, all of Plant 2 would get minimized. If I were to expand plant 2 manually then click on Plant1>Tank1, again then Plant 2 would once again get minimized. Ideally I’d like for Plant 2 to stay expanded until I manually minimized it.
