Regarding cdf's DataBase and usage of Spark SQL
Hello Community,
cdf stores the data in cloud, could  anyone know what is the database / database structure being used,
and any reason for using Spark SQL for transformations.
Hi @Viswanadha Sai Akhil Pujyam,
I hope the above helped. I’m closing this topic now, please feel free to create a new post if you still experience problems.
Hi!
The short answer wrt using Spark SQL for the transformations is that we use Spark as a technology component in the Transformations Service/API.
As for the database or DB structure used in CDF, the answer depends on the service. We don’t use a single DB or DB schema, and in some cases we don’t even use a “default” DB schema at all (the “schema” - but it isn’t actually a schema - depends on the data).
Since we expect our users (developers) to - for those we have available - interact with the resources through the API surface, I'm unclear as to what you’re wanting to achieve by having the requested information?
joar.saether
  • Director Site Reliability Cognite
  • October 25, 2023
Can you take a look at these two documents that covers Backup and Disaster recovery:
I think they may contain some of the information you are looking for if your question is about how we organize the storage backends in general.
  • October 31, 2023
Hi @Viswanadha Sai Akhil Pujyam, did the above help you?
