Could not publish a datamodel if TimeSeries is used in the graphql schema through the UI
If  publishing a datamodel with TimeSeries attributes defined(like below)in the UI, it will fail with an error message:
type Property {
  modelName: String
  value: TimeSeries
Best answer by David Liu
Hi @Xiaofeng Wang ,
Sorry this feature is still work in progress at the moment, we will announce the release for support for TimeSeries the moment it is available. For now, as a work around, can you store the externalId as String field types for now?
Sorry for the inconvenience,
David
David Liu
  • March 1, 2023
Hi @Xiaofeng Wang ,
David
Thanks for the reply. Will use String type for now.
