Issue:
When we install Cognite python SDK if you are observing an error warning as below,
WARNING: Discarding https://files.pythonhosted.org/packages/25/50/0466d5d83e1859c5ca38351ee932d64cc5635f9d4dad522879e58f4b0018/Fiona-1.8.2.tar.gz#sha256=4c6419b7ac29136708029f6a44b4ccd458735a4d241016c7b1bab41685c08d8f (from https://pypi.org/simple/fiona/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.Downloading Fiona-1.8.1.tar.gz (1.1 MB)|████████████████████████████████| 1.1 MB 3.2 MB/sERROR: Command errored out with exit status 1:command: 'c:\users\mithila\appdata\local\programs\python\python39\python.exe' -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\mithila\AppData\Local\Temp\pip-install-3ru45mbx\fiona_e5daa4b655dd467bb03096ab64aa19ae\setup.py'"'"'; file='"'"'C:\\Users\mithila\AppData\Local\Temp\pip-install-3ru45mbx\fiona_e5daa4b655dd467bb03096ab64aa19ae\setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(file) if os.path.exists(file) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' egg_info --egg-base 'C:\Users\mithila\AppData\Local\Temp\pip-pip-egg-info-7wzx320y'cwd: C:\Users\mithila\AppData\Local\Temp\pip-install-3ru45mbx\fiona_e5daa4b655dd467bb03096ab64aa19aeComplete output (1 lines):A GDAL API version must be specified. Provide a path to gdal-config using a GDAL_CONFIG environment variable or use a GDAL_VERSION environment variable.----------------------------------------
Possible causes:
The latest Windows versions are not fully supported to some python versions.
SDK is not optimized to the latest python versions.
Solution/Workaround:
Create a python virtual environment and install the Cognite python SDK in it.
Steps to create a python virtual environment:
- Open a terminal and create a directory and navigate to it.
C:\Users\mithila>mkdir pythonvm
C:\Users\mithila>cd pythonvm
Install the
virtualenvpackage
pip install virtualenv
Create the virtual environment
virtualenv mypython
Activate the virtual environmen
mypthon\Scripts\activate
Then install Cognite SDK
pip install cognite-sdk
Check the
documentation
Ask the
Community
Take a look
at
Academy
Cognite
Status
Page
Contact
Cognite Support
