Aker BP
Forum|alt.badge.img+6
Hello! Is there a repository where the Aker BP open data is available for direct download? ( asset hierarchy, work orders, P&ID file)?
Best answer by Andre Alves
Hi @Raluca Bala
I'm currently using the repositories listed below. However, both of them are similar, and the last update was four years ago.
If this is for training purposes, I would assume that the only publicly available data is within the 'publicdata' project in Cognite Data Fusion.
If you happen to find something else, please share.
Regards, Andre
Andre Alves
Forum|alt.badge.img+13
  • MVP
  • 147 replies
  • November 16, 2023
Hi @Raluca Bala
Regards, Andre
  • 16 replies
  • November 17, 2023
Hi Andre,
Thank you. That's right. One can only connect to that data through sdk.
Raluca
