Extracting Asset Hierarchy from PDF P&IDs in Cognite Data Fusion
  • October 29, 2024
  • 9 replies
  • 114 views
Andre Alves
Forum|alt.badge.img+13
In a hypothetical scenario where we need to extract asset hierarchy directly from PDF-based P&ID documents, does Cognite provide a built-in library to support this? Or would we need to rely on external libraries like PyMuPDF or pdfplumber for data extraction—or even tools like Pytesseract in cases involving scanned images?
Thank you for any guidance on best practices or integrations for this use case!
Best answer by Que Tran
Hi @Andre Alves,
You can use the API (like in the script I shared earlier) to extract tags directly from P&IDs without needing to pre-contextualize the files. The API inputs are the patterns you want to extract, so there’s no need for assets to already exist in the CDF.
Que Tran
Elcio Cardoso da Silva
Forum|alt.badge.img+7
Two years ago we used the Python library Pytesseract in another project, not related to Cognite. However, we faced some challenges since the names of the elements we needed weren’t laid out in a straight line throughout the document. In some cases, the labels were inside a circle, with each part of the name in a separate semicircle. At that time, the results weren’t satisfactory, with a low success rate.
Andre Alves
  • MVP
  • 143 replies
  • October 30, 2024
Thank you, @Elcio Cardoso da Silva . We’re aware of this project, but our main objective here is to determine if there’s any built-in solution within Cognite that we could leverage.
Cognite Team, if you have any insights or suggestions regarding this, please share them with us.
Thanks again!
Andre Alves
  • MVP
  • 143 replies
  • November 1, 2024
Hi @Anita Hæhre
Could you help me connect with someone at Cognite regarding a question for a client proposal? I'm exploring whether we can leverage a Cognite OCR feature or something similar.
One of the source systems for building the asset hierarchy is based on P&ID documents, screenshots, and other documentation, as the client doesn’t have a consolidated asset hierarchy in a system like SAP.
Thank you very much for any guidance on this!
  • 590 replies
  • November 4, 2024
Hi @Andre Alves  apologies for the delayed response - I was away on a short holiday. I’ll update you here as soon as I’ve identified the best person to follow up on this. Thanks for your patience!
Andre Alves
  • MVP
  • 143 replies
  • November 5, 2024
No need to apologize @Anita Hæhre ! You’re always incredibly helpful, and I’m very grateful for your assistance. I’ll be waiting for your update, and thanks in advance for your help.
  • 43 replies
  • November 8, 2024
Hi @Andre Alves ,
Thank you for the question :)
You can extract tags in engineering diagram using the Diagram parsing service in Beta with `pattern_mode` enabled. This mode allows you to provide a list of examples, and the service will identify tags that follow similar patterns.
The sample field can be string, or list of alternative strings. Each string defines a pattern. E.g. 21-PT-1019 enables detecting tags consisting of 2 digits, 2 letters and 4 digits. Special characters are not necessary for detecting, but will be included in the detected string. It is possible to mark parts of the sample as constant strings by enclosing them in square brackets. Within square brackets, a | character can be used to separate alternative constants. Alternative constants must be either all digits or all letters.
Here is an example code which can be run in Cognite Jupyter Notebook:
from cognite.client.config import FusionNotebookConfig
from cognite.client.data_classes.contextualization import FileReference
# Instantiate Cognite SDK client:
client = CogniteClient(FusionNotebookConfig(api_subversion="20230101-beta"))
entities = [
                "sample":"PT-01-AB",
                "resourceType":"instrument"
        ] # declare your patterns and resource types (optional)
file_references = [
    FileReference(file_id=..., first_page=1, last_page=1)
model = client.diagrams.detect(
    entities=entities,
    file_references=file_references,
    pattern_mode=True,
    partial_match=True,
model.result
Hope it helps :)
Que Tran
Andre Alves
  • MVP
  • 143 replies
  • November 12, 2024
Thanks, @Que Tran . We’re currently in discussions with some clients who face challenges in managing asset hierarchies. One approach we're exploring is using P&ID files to identify tag patterns and automatically build the hierarchy. Could you clarify if it’s possible to use the API without pre-contextualizing the files? The idea is to process these files (e.g., through OpenCV) to establish the hierarchy first, and then, once we have an asset hierarchy in place, begin the contextualization process.
  • 43 replies
  • November 13, 2024
Hi @Andre Alves,
Que Tran
Andre Alves
  • MVP
  • 143 replies
  • November 14, 2024
Thanks again, ​@Que Tran  Your help has been fantastic.
We’ll definitely be using it, and we’ll let you know if we encounter any issues or challenges.
Have a great day!
