Parked
Infield : Mobile Device
Related products:InField
  • February 27, 2024
  • 17 views
Using the Infield with the small screen of mobile devices can be a challenge with current layout of the Infield screen. The text are small and navigating left + right and up + down can be difficult with narrow width of the Checklists and Assets Explorer Section.
To begin with, Infield tries to put 3 section of information (All Checklists, Checklists, Assets Explorer) into the screen of mobile device the same way for potrait and landscape mode. While in Landcape mode, the adaptation seems ok but in Potrait mode, with example a 6 inch display, the assets explore section is only partially displayed on the screen. It is not possible to navigate left or right to see the rest of the Assets explore section because the sections are fixed. This arrangement also made the fonts smaller as the sections are squeezed and scrolling up and down difficult.
There are 2 methods to improve the UI for Potrait mode for the field people, 1) To arrange the sections in a vertical manner instead of horizontal. Disadvantage of this is there will be a lot of scrolling up and down to get from 1 section to another. 2) To separate each section to a tab (refer to-be worksheet). This enlarges the font size, increases the width of each section and improves the scrolling and ease of data entry for the field workers.
Infield should be intelligent enough to identify between potrait mode and landscape mode and change the UI according to the display mode as field users can use mobile devices and also tablets in either modes.
Hi @Gary Goh ! Thanks for reaching out.
Without seeing a picture of your mobile screen I might be wrong here, but I do believe that the mobile device you are using seem to be prompting desktop behaviour. In short, InField should change what and how features are displayed when going from desktop to mobile.
In cases where InField isn’t able to recognise the device you can actually do this yourself. On the mobile device, click on your user profile (top right corner) → device mode → mobile. This will make mobile default for that particular device.
Does this solve your need?
Br,
Kristoffer
