Is it possible to get Cognite Data Fusion APIs from Minitab application? If does, how does it work the connection?
Ho to connect Minitab to Cognite Data Fusion
As per my knowledge Cognite does not have a connector to integrate Cognite Data Fusion (CDF) with Minitab. But as a workaround have you tried writing Python scripts in Minitab to connect to the CDF using the cognite-sdk
library?
More infromation regarding the Python SDK can be found here.
Mithila
