Contextualizing engineering diagrams
  • November 30, 2023
  • 63 views
In the video of contextualizing engineering diagrams (say P & ID), can you explain more what data is exactly fetched from these and how it is contextualized? Is it just names of the tags or much more than that is done ? Do we use some vision algorithms to understand which equipment is connected to other equipment ? Or we just fetch the name of tags using some parser from the image file ?
Best answer by Nimesh Madandas
Hi @Manoj Gupta,
I understand that you have quite a few questions regarding contextualizing P&ID diagrams, and as an Academy instructional designer, I am here to help you out.
I am providing you with a link → https://learn.cognite.com/path/cognite-data-fusion-fundamentals/contextualization-fundamentals/1629509 ; the URL takes you directly to the lesson you would like to refer to as it contains the videos that will help with understanding the concept better. You can jump into the ‘Create interactive engineering diagrams' video to get all your questions answered.
Also, for better understanding, you could try contextualizing P&IDs yourself by performing the hands-on; here's the link to the LP → https://learn.cognite.com/path/cognite-data-fusion-fundamentals.
Let me know if you have any questions or get stuck somewhere. Happy learning!
Best,
Nimesh Madandas
Senior Instructional Designer - Academy
Nimesh  Madandas
Forum|alt.badge.img+5
  • November 30, 2023
Hi @Manoj Gupta,
Best,
Nimesh Madandas
  • December 8, 2023
Hi @Manoj Gupta,
We are following up to see whether you're satisfied with the responses you've received.
If you found the responses offered by our community members to be instructive and helpful, we kindly request that you consider marking the most helpful response as the "Best Answer."
Br,
  • December 15, 2023
Hi @Manoj Gupta,
As of now, I will close this thread. Let me know if you have any questions.
Br,
