Unit testing for cognite extractors using pytest framework ---cogex based extractors
  • October 18, 2023
  • 62 views
Hi Team,
IS there any unit testing examples for cogex based extractors to test integration with rest api
Best answer by Andre Alves
As mentioned by @mathialo , you can simply refer to the pytest documentation for guidance. However, if you're looking for some examples, you can explore the Cognite GitHub repositories. Below is a simple example of a validation unit test in the Cognite Python SDK:
https://github.com/cognitedata/cognite-sdk-python/blob/master/tests/tests_unit/test_utils/test_validation.py
  • October 19, 2023
In terms of testing it’s just a normal python codebase, so there is nothing special you need to do. Just follow pytest’s documentation as normal.
Andre Alves
Forum|alt.badge.img+14
  • MVP
  • October 20, 2023
