Hi Team,
When i updated extractor.py file to upoad excel data into CDF and execute poetry run csvextractor example_config.yaml commanad im getting below error
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\_api_client.py", line 272, in _url_is_retryable
raise ValueError(f"URL {url} is not valid. Cannot resolve whether or not it is retryable")
ValueError: URL /api/v1/projects/${COGNITE_PROJECT}/raw/dbs/my-db/tables/my-table/rows is not valid. Cannot resolve whether or not it is retryable
Below is the complete error:
PS C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor> poetry run csvextractor example_config.yaml
No config type specified, default to local
2023-10-16 04:56:27.050 UTC [INFO ] MainThread - No .env file found
2023-10-16 04:56:27.051 UTC [WARNING ] MainThread - No config type specified, default to local
2023-10-16 04:56:27.051 UTC [INFO ] MainThread - Loaded local config file
2023-10-16 04:56:27.052 UTC [INFO ] MainThread - No extraction pipeline configured
2023-10-16 04:56:27.054 UTC [ERROR ] MainThread - Unexpected error during extraction
Traceback (most recent call last):
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\csvextractor\__main__.py", line 17, in main
extractor.run()
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\extractorutils\base.py", line 359, in run
self.run_handle(self.cognite_client, self.state_store, self.config, self.cancellation_token)
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\csvextractor\extractor.py", line 24, in run_extractor
with RawUploadQueue(cdf_client=cognite, max_queue_size=100_000) as queue:
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\extractorutils\uploader\raw.py", line 175, in __exit__
self.stop()
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\extractorutils\uploader\_base.py", line 133, in stop
self.upload()
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\extractorutils\uploader\raw.py", line 128, in upload
self._upload_batch(database=database, table=table, patch=list(patch.values()))
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\decorator.py", line 232, in fun
return caller(func, *(extras + args), **kw)
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\extractorutils\util.py", line 399, in retry_decorator
return _retry_internal(
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\extractorutils\util.py", line 344, in _retry_internal
return f()
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\extractorutils\uploader\raw.py", line 152, in _upload_batch
self.cdf_client.raw.rows.insert(db_name=database, table_name=table, row=patch, ensure_parent=True)
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\_api\raw.py", line 393, in insert
summary.raise_compound_exception_if_failed_tasks(
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\utils\_concurrency.py", line 72, in raise_compound_exception_if_failed_tasks
collect_exc_info_and_raise(
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\utils\_concurrency.py", line 120, in collect_exc_info_and_raise
raise unknown_exc
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\utils\_concurrency.py", line 269, in execute_tasks
res = f.result()
File "C:\Users\srama2\AppData\Local\Programs\Python\Python311\Lib\concurrent\futures\_base.py", line 449, in result
return self.__get_result()
File "C:\Users\srama2\AppData\Local\Programs\Python\Python311\Lib\concurrent\futures\_base.py", line 401, in __get_result
raise self._exception
File "C:\Users\srama2\AppData\Local\Programs\Python\Python311\Lib\concurrent\futures\thread.py", line 58, in run
result = self.fn(*self.args, **self.kwargs)
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\_api_client.py", line 152, in _post
return self._do_request(
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\_api_client.py", line 175, in _do_request
is_retryable, full_url = self._resolve_url(method, url_path)
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\_api_client.py", line 247, in _resolve_url
is_retryable = self._is_retryable(method, full_url)
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\.venv\Lib\site-packages\cognite\client\_api_client.py", line 262, in _is_retryable
return method in ["GET", "PUT", "PATCH"] or method == "POST" and self._url_is_retryable(path)
File "<string>", line 1, in <module>
extractor.run()
self.stop()
self.upload()
return f()
raise unknown_exc
res = f.result()
2023-10-16 05:01:18.771 UTC [INFO ] MainThread - No .env file found
2023-10-16 05:01:18.775 UTC [WARNING ] MainThread - No config type specified, default to local
2023-10-16 05:01:18.775 UTC [INFO ] MainThread - Loaded local config file
2023-10-16 05:01:18.775 UTC [INFO ] MainThread - No extraction pipeline configured
2023-10-16 05:01:18.775 UTC [INFO ] MainThread - Extracting {file.path}
2023-10-16 05:01:18.778 UTC [ERROR ] MainThread - Unexpected error during extraction
extractor.run()
File "C:\Users\srama2\Documents\Shravan\Training\Cognite\csvextractor\csvextractor\extractor.py", line 27, in run_extractor
self.stop()
self.upload()
return f()
raise unknown_exc
res = f.result()
extractor.run()
self.stop()
self.upload()
return f()
raise unknown_exc
res = f.result()
