Can we use Cognite OPC UA extractor for extracting Bentley Assetwise APM data?
  • September 21, 2023
  • 56 views
We want to extract data from Bentley AssetWise APM. Can Cognite OPC UA Extractor be used for this use case? If yes, how? If no, which Extractor from Cognite’s prebuilt extractors is suitable for this?
Best answer by Christian Mueller
Hi, thanks for your question.
We have both OPC UA and OPC Classic Extractors available. It seems Bentley AssetWise APM has an OPC DA (OPC Classic) Server, but please confirm with the software vendor (Bentley) if the version running on the customer environment has either an OPC UA (preferred method) or DA so our extractors can be used to extract data from. Depending on the protocol available on the source system, different extractors may be used (OPC UA, OPC DA, DB etc).
Best Regards,
Christian Mueller
Christian Mueller
Best Regards,
Christian Mueller
