CDF-Learning. Data Transformation with different error
I am following the Cognite training and trying to create the asset data transformation. when hit Run bottom it shows a different error on each run. can understand what is the root cause and the mitigation action. Appreciate feedback. Thanks
ever display the exactnumber of 36 rows we have in the asset.csv file
Best answer by Sofie Haug
Hi @Eddy Ramon Gimenez Moreno!
Looking into the transformations you’ve ran, I see that you have successfully created your assets!
You selected “create assets” instead of a asset hierarchy. Then it tries to make them one by one and throws an error if the paren of the asset it is trying to create doesn’t exist yet. While choosing asset hierarchy we avoid this issue. Why it reads a different number, I’m not sure about, but we do see that when asset hierarchy is selected it reads the correct number (36)!
Good luck with the rest of the training!
Sofie Haug
Forum|alt.badge.img+7
  • 161 replies
  • September 5, 2023
Thanks, Sofie for your feedback. Now it is working. Warm regards
