Hosting a web-hook endpoint in a cognite function
Hi, is it possible to host a web-hook endpoint in a Cognite function?
And is it a good idea?
Best answer by Ivar Stangeby
Hello Czach!
When you say “host a web-hook endpoint”, do you mean spinning up an API endpoint in the Cognite Function, for instance using Flask or FastAPI? Can you help me understand your specific use case?
You won’t be able to keep this server alive, as each Cognite Function invocation has a specific execution time limit.
Ivar Stangeby
  • 22 replies
  • August 30, 2023
Hello Czach!
Ivar Stangeby
  • 223 replies
  • September 11, 2023
Hi @czach, would you be able to help out with some details?
