Merging Charts Y axis
  • August 11, 2023
  • 25 views
In CDF Fundamentals class for Cognite Charts it states that one can merge the both y axis for Sunction, Discharge and Delta, but it doest state how its done. Any guidance on how to merge or make sure chart only shows one y axis?
Best answer by Dariush
I guess I found it it was on the top of chart next to y-axis. Nevertheless maybe its good to mention that hint in that in the lesson @Sofie Haug
  • August 11, 2023
  • August 14, 2023
Hi @Dariush, great that you were able to sort this out. I have also informed the Academy team about your suggestion. Have a nice day!
I have selected Merge Units, but my Detla T is still showing on a separate axis. Suction and Discharge side tempuratures are merged though.
How do you merge everything?
I found the solution - the units for the Delta P/T series needs to be set to bar/celcius then the y axes will merge :)
