Unstable call for the instance creating
  • August 1, 2023
  • 58 views
We saw quite frequently an error message like below:
"could not add instances: 500 - Internal server error. Please report this error to support@cognite.com and provide us with your request id: 4594f717-51c0-9708-86d3-5c5431f60cd1 and cluster name: westeurope-1"
But when run it again it worked. The issue happens quite often(the number of instances in the request is close to 1000), could you have a check? Thanks.
Xiaofeng
Best answer by Carin Meems
Hi @Xiaofeng Wang, I’ll close this thread for now based on Jason’s reply above. In case you come across the same situation, feel free to open a ticket with our Support team via support@cognite.com.
  • August 2, 2023
@Xiaofeng Wang
Thank you for sharing this.  I have reported.  I will get back to you with any updates 😀
-Jason
  • August 17, 2023
@Xiaofeng Wang , unfortunately support was not able to retrieve the logs for your request.  We’re working on a process to respond asap to these so we can provide better support.
Jason
  • September 11, 2023
