I uploaded a CSV into a raw table in cognite data fusion. Now I have seen the raw table and see 200 numeric columns and 2 text columns are present. When i come to SDK and retrieve the rows from the same table as dataframe, it is showing 199 columns as numeric and 3 text columns. there was one specific column '0NA' which was originally a numeric column now shows the datatype as 'object' instead of 'float64'. I checked and there are no null values and no other NaN characters and it's just decimal values all across.
When I fetch all numeric columns directly from CSV, I see the column as float-64 but after importing that CSV into RAW table, it is doing something else.
I tried to see the unique values in the column and found these two as string,I suppose.
In CSV , they were stored as number but when uploading to RAW table, it does convert into something like this.
Please help if RAW table cannot accommodate values with more than 10E142 values such as these?.
How to handle this scenario.
'24100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000000000000000000000000000' '3950000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000000000000000000000000000'
