Cognite function with pandas
  • July 12, 2023
  • 50 views
Hi, when I create a function that imports pandas I get  ModuleNotFoundError: No module named 'pandas'
I expected that the function was hosted in a pre-configured runtime environment with many commonly used libraries already installed, including pandas.
Any idea what I am doing wrong?
Best answer by Chyrus Ramesh
Hi @czach ,
The Cognite-SDK no longer provides pandas by default. It can be installed using cognite-sdk[pandas] . Specifying that in the requirements.txt will able to fix this issue.
Thank you.
Best regard,
Chyrus
  • July 13, 2023
Hi @czach ,
Thank you.
Best regard,
Chyrus
