Entity matching dataset not available in dropdown
  • January 10, 2023
  • 7 replies
  • 75 views
Forum|alt.badge.img+4
I was trying to complete learning exercise in contextualization. I’m nit able to find dataset ‘saurabh1985-IFSDB’ created by me in initial exercise. Please check image below.
Can you please help me with issue ?
thanks,
Saurabh Lale
Best answer by Carin Meems
Hi both, just wanted to inform you that engineering has fixed the issue. Happy learning!
  • January 10, 2023
Hi @Saurabh Lale
Thanks for reporting. This is a known issue that our engineering team is working on. I’ve created a Support ticket, and we’ll keep you updated via that. For now you’ll have to unfortunately skip this part of the course, or try to create a dataset from scratch.
Have a nice day!
Carin
  • January 10, 2023
​​​@Carin Meems ,
not sure if it helps, but in my case events/entities are searchable, but assets are not.
hope it’ll be fixed soon,
yakov
  • January 10, 2023
Hi @ykozlov
Thanks for letting me know, that sounds like slightly different behavior from what we’re currently addressing. I’ll create a ticket for you, and Support will reach out to get some more details.
Carin
  • January 10, 2023
@Carin Meems
I was able to search when I recreated dataset. This time while giving the name, i started with capital letter. Im not sure if thats the issue or not.
thanks,
Saurabh
  • January 11, 2023
@Saurabh Lale great that you were able to find it now. From my understanding that should not be the issue, though. Engineering is looking into it, we’ll let you know when it’s sorted :)
  • January 13, 2023
  • January 16, 2023
Hi ,
Thanks a lot for resolving issue. However, i was anyway able to complete the lesson with suggested workaround and all the datasets have been archived now as per lesson instructions.
thank,
Saurabh
