I am using the [Cognite Data Fusion Python SDK](https://cognite-sdk-python.readthedocs-hosted.com/en/latest/data_modeling.html#delete-instances).
While deleting a node, e.g....
```python
client.data_modeling.instances.delete(NodeId(space='some-space', external_id=deleted_node_id))
I want to also delete the edge(s) from the parent in order to avoid leaving orphan edges in the database.
**Problem**: how can I look-up such edges?
I know how to get all edges (and then filter by the `end_node` attribute), but that would be very inefficient:
```python
edges = client.data_modeling.instances.list(
instance_type="edge", limit=-1)
How could I construct the `Filter` for the `end_node` (to match the `deleted_node_id`) and ideally the `type` (to equal `Child` type)? E.g.
```python
filter=And(Equal(???), Equal(???)),
limit=-1)
Because then I could just delete all those edges with one `client.data_modeling.instances.delete(edges)` call.
