Pygen shorter attribute names
  • March 11, 2025
  • 50 views
Olav Alstad
We have a RDF-model based on CIM that we have imported to CDF Data Model via Neat. We are experimenting with Pygen. We are happy about both NEAT and Pygen and looking forward to explore further.
The names of the attributes of the dataclasses becomemes long with pygen and the CIM-naming convension.
Example 1:
  • Model: cim:IdentifiedObject.name
  • pygen: identified_object_name
  • proposed pygen short: name
Example 2:
  • Model: nek:NEKACLineSegment.wireSegmentKind
  • pygen: nekac_line_segment_wire_segment_kind
  • proposed pygen short: wire_segment_kind
Generic:
  • Model. namespace:ClassName.attrName
  • pygen: class_name_attr_name
  • proposed pygen short: attr_name
Is it possible to add an option in pygen to genreate short attributes? The rule would be to only the string followed by the . (dot )
I’m also interested in discussing other solutions with you. One options is ofc to change the names in the model, but then we are not conforming to CIM…
Olav
Best answer by Anders Albert
I am in general skeptical about this type of functionality as it seems very custom. It also seems to promote poor property naming. Does cim really expect you to repeat the class in every property? This seems to be cumbersome to have in the data model in the first place.
Forum|alt.badge.img+8
@Olav Alstad The engineers from the related team will get back to you with an update.
Anders  Albert
  • March 11, 2025
Olav Alstad
  • March 12, 2025
Thanks for reply Anders. I see what you mean and understand that you are skeptical. You can keep note of it, in case some other ask for the same. No problem for us that it will not be implemented, we are still in discovvering phase.
Yes, naming convension in CIM is like that. CIM use inheritance. An ACLineSegment do have many properties, but here are three of them:
  • cim:IdentifiedObject.name
  • cim:Conductor.length
  • cim:ACLineSegment.r
As you can see, the class name in the property show which class the attribute is inherited from. This is actually nice to have, but I think the attribute name in the pygen generated dataclass is a bit long. I can live with that, or consider to change name of the properties in the Data Model.
Olav
