How to populate Edge properties?
  • February 27, 2025
  • 29 views
I understand that we can define properties on edges, but it isn’t clear from the documentation how these properties are populated. I am trying to implement the following model
And defined the data model using DML as follows
How can I add a UserActivity edge with properties start_time and stop_time, that I can read while listing all the activities that a User has performed?
Thank you
Best answer by Arild Eide
Hi ​@Yatish Pitta
The model definition you have provided will create a view UserActvitivy and a corresponding container to hold the edge properties. To populate edges you can use the Python SDK like this:
import cognite.client.data_classes.data_modeling as dm
client = CogniteClient()
client.data_modeling.instances.apply(
        edges=dm.EdgeApply(
            space=space_name,
            external_id="user_activity001", # external id of the edge you are creating
            type=dm.DirectRelationReference(space=space_name, external_id="User.activity"),  # Required type property
            start_node=dm.DirectRelationReference(space=space_name, external_id="activity001"), # Assuming presence of this activity node
            end_node=dm.DirectRelationReference(space=space_name, external_id="user001"), // Assuming presence of this user nade
            sources=[
                dm.NodeOrEdgeData(
                    # View version for UserActivity is auto created
                    source=dm.ViewId(space=space_name, external_id="UserActivity", version=version),
                    properties={"start_time": "2025-02-28T09:00:00", "stop_time": "2025-02-28T09:01:00"},
Hope this helps.
Arild Eide
  • 38 replies
  • February 28, 2025
Hi ​@Yatish Pitta
        edges=dm.EdgeApply(
            space=space_name,
            sources=[
                dm.NodeOrEdgeData(
Hope this helps.
Arild Eide
