Events transformation data set
I am on the CDF Fundamentals learning path and is currently on the “Events Transformation” section.
I am trying to create a data set named “FirstnameBirthyear-IFSDB”. I do not see an attached dataset at the bottom of the page, do I use the same dataset (assets CSV file) as before?
The external ID for the new IFSDB dataset is 8667716811777202.
Best answer by Maritsa Sarri
Hi ​@staceymhli! Happy New Year!
You don´t need to upload any files in order to create a dataset. If you follow the instructions exactly you should be able to move forward. Let me know if you have any issues moving forward.
Maritsa Sarri
Forum|alt.badge.img+10
  • 23 replies
  • January 2, 2025
  • January 2, 2025
Hi ​@Maritsa Sarri ,
Thank you for your reply. I had an error previously when I tried to preview it, but it works fine now, perhaps it was just a little laggy/buggy.
Thanks again!
