Duplicate data when reading timeseries into Power BI
  • October 20, 2022
  • 60 views
Glen Accardo
Active
I have found a problem reading timeseries from Cognite with Power BI. The first bit of Power Query has a filter to limit the timeseries retrieved to just the ones I want. The second one is the same, but does not have the filter. What I have found is that adding the filter causes duplicate rows in the table. Once the timeseries rows are duplicated, the timeseries aggregation values are also duplicated. I know that the first query is not the most performant option, but it should still have the correct answer.
let
    Source = Cognite.Contents( #"cogniteContentsParameters", #"cdfEnvironment"),
    Timeseries_table = Source{[Name="Timeseries",Signature="table"]}[Data],
    #"Filtered Rows" = Table.SelectRows(Timeseries_table, each ([IsString] = false)),
    #"Removed Columns" = Table.RemoveColumns(#"Filtered Rows",{"MetaData", "SecurityCategories", "IsStep", "DataSetId", "CreatedTime", "LastUpdatedTime", "Asset", "Latest", "DataPoints", "StringPoints", "Aggregate"}),
    #"Filtered Rows1" = Table.SelectRows(#"Removed Columns", each ([Name] = "oil-production-rate" or [Name] = "gas-production-rate" or [Name] = "water-production-rate"))
in
    #"Filtered Rows1"
let
in
    #"Removed Columns"
Best answer by Carin Meems
Hi Glen,
We’ve tried to reproduce the problem you’re facing, but are currently unable to do so. We’d like to dig a little further in the issue, so we’ve created a Support ticket for this. We’ll be following up with you in that ticket.
Have a nice day!
Carin
  • 223 replies
  • October 21, 2022
Hi Glen,
Have a nice day!
Carin
