Issues with asset transformation code
  • November 26, 2024
  • 41 views
In working with CDF: Integrate, I am trying to transform the asset csv file using the following code:
SELECT
concat('Ruby2001:',loc) as externalId,
IF(parent_loc='' OR parent_loc IS NULL, '', concat('Ruby2001:',parent_loc)) AS parentExternalId,
CAST(lastUpdatedTime AS STRING) AS name,
to_metadata(*) AS metadata,
description AS description,
2869936105026304 AS dataSetId
FROM `Ruby2001`.assets
However I keep getting this error message:
Column 'parent_loc' does not exist. Did you mean one of the following? [z6eecbaa9603c4ee195055fe6aaeb89a3.loc, z6eecbaa9603c4ee195055fe6aaeb89a3.key, z6eecbaa9603c4ee195055fe6aaeb89a3.name, z6eecbaa9603c4ee195055fe6aaeb89a3.parent_loc,,, z6eecbaa9603c4ee195055fe6aaeb89a3.WMT_TAG_ID, z6eecbaa9603c4ee195055fe6aaeb89a3.description, z6eecbaa9603c4ee195055fe6aaeb89a3.WMT_SYSTEM_ID, z6eecbaa9603c4ee195055fe6aaeb89a3.lastUpdatedTime]; line 3 pos 3; 'Project [concat(Ruby2001:, loc#41009138) AS externalId#41009101, 'IF((('parent_loc = ) OR isnull('parent_loc)), , 'concat(Ruby2001:, 'parent_loc)) AS parentExternalId#41009102, cast(lastUpdatedTime#41009134 as string) AS name#41009103, map_from_arrays(array(key, lastUpdatedTime, WMT_SYSTEM_ID, WMT_TAG_ID, description, loc, name, parent_loc,,), array(cast(key#41009133 as string), cast(lastUpdatedTime#41009134 as string), cast(WMT_SYSTEM_ID#41009135 as string), cast(WMT_TAG_ID#41009136 as string), cast(description#41009137 as string), cast(loc#41009138 as string), cast(name#41009139 as string), cast(parent_loc,,#41009140 as string))) AS metadata#41009104, description#41009137 AS description#41009105, 2869936105026304 AS dataSetId#41009106L] +- SubqueryAlias z6eecbaa9603c4ee195055fe6aaeb89a3 +- View (`z6eecbaa9603c4ee195055fe6aaeb89a3`, [key#41009133,lastUpdatedTime#41009134,WMT_SYSTEM_ID#41009135,WMT_TAG_ID#41009136,description#41009137,loc#41009138,name#41009139,parent_loc,,#41009140]) +- Relation [key#41009133,lastUpdatedTime#41009134,WMT_SYSTEM_ID#41009135,WMT_TAG_ID#41009136,description#41009137,loc#41009138,name#41009139,parent_loc,,#41009140] RawTableRelation(db=Ruby2001, table=assets) | code: 400 | X-Request-ID: ce89d63f-1c78-97d2-9165-88b8621e92dd
I have checked the original asset csv and the variables are there but separated by a ‘;’ - should they be separated by ‘,’ instead? Thanks
Best answer by Sofie Haug
Hi ​@rubyhaddad_01  I had a look at your CSV file, and I’m not sure, but somethings seems a bit strange. The loc column and all it’s values have had some extra commas added at the end. Can you try to delete the raw table and uplaod the file again?
Jan Inge Bergseth
I would recommend to split this in 2 Transformations.
First just creating all the Assets, then as second Transformation create the connection  with parent_loc
Jan Inge Bergseth
with 2 transformations you make sure the “parent” node is written to the backend before you try to connect to it.
But required that the data actually contain the parent so the child's have a parent
Sofie Haug
Forum|alt.badge.img+7
  • 157 replies
  • November 26, 2024
Sofie Haug
  • 157 replies
  • November 26, 2024
I also tried to read form a diffent table, and then it was all good! So nothing wrong with the SQL code part, just the RAW table itself.
