Bug: Curl Example Syntax is Invalid For dataModel ACLs
  • September 21, 2022
  • 38 views
Ben Brandt
The curl command suggested here needs quotes around all JSON property names, needs to use " instead of ', and needs trailing commas removed before curl will stop reporting invalid JSON payload.
Best answer by Anders Hafreager
Hi, thanks for reporting this. This is absolutely true! We have decided to remove the CURL and Python example since this is possible to configure using the UI.
Configuring ACLs will be added to the CLI tool soon.
Anders Hafreager
