Hosting pickle file in CDF
  • September 11, 2024
  • 38 views
Hello,
Is it possible to host a pickle file (which contains a ML model) in CDF and use it to make predictions for the available data in the platform?
If yes, what are the steps ? I browsed the documentation but I haven’t found anything relevant
Best answer by JonHaslanger
Hello,
A pickle file can be uploaded to CDF as a standard “file” type of data.   Then you can call the file via the API from your python code as a bytestream using the client.files.download_bytes(id=<fileID>)
Regards
-Jon
  • September 13, 2024
Hello,
Regards
-Jon
