Unable to sign up for grafana
  • September 5, 2022
  • 88 views
Divyanshi Mangal
I get this when I am trying to sign up from grafana with my Azure AD linked account dmangal@slb.com.
Any idea how to solve this?
Best answer by Torgrim Aas
Hi!
This is a common error when using an application that is trying to authenticate via Active Directory but has not been approved yet by your Active Directory administrator. If a user with Active Directory administrator privileges tries to sign in as you just did, the person would have been asked if Grafana should be approved, and from that point of you would also be allowed to use it.
More information is here: https://docs.cognite.com/cdf/dashboards/guides/grafana/admin_oidc/#step-1-register-grafana-as-an-application-in-azure-ad
Note that such application authorization is normally required for each location where an application is hosted, hence several authorizations for the same application might be required.
Torgrim
Torgrim  Aas
  • September 5, 2022
Hi!
Torgrim
  • September 6, 2022
Hi @Divyanshi Mangal!
Did Torgrim’s answer help you?
  • September 6, 2022
@Divyanshi Mangal I have responded on the SLB:Cognite Teams channel.
@Jason Dressel , can u please send us the link of the SLB:Cognite Teams Channel
