Cascading delete of instance
Hi!
Is there a way to enable cascading deletes for instances for both direct relations and edges?
Edit: I posted in the wrong group, but i don’t think i can delete.
Best answer by Andre Alves
Hi @Erik Wiker!
As far I know Cognite CDF does not natively support cascading deletes for instances through both direct relations and edges. To achieve cascading deletes, you would typically need to implement custom logic within your application or python sciprt as follow.
def delete_instance_and_related(client, instance_id):
    # Find all relationships and edges related to the instance
    relationships = client.relationships.list(target=instance_id)
    edges = client.edges.list(target=instance_id)
    # Recursively delete related instances
    for relationship in relationships:
        delete_instance_and_related(client, relationship.source_id)
    for edge in edges:
        delete_instance_and_related(client, edge.source_id)
    # Delete the instance itself
    client.instances.delete(instance_id)
# Initialize the Cognite Client
client = CogniteClient()
# Call the function with the ID of the instance to delete
For detailed information you can go to
https://cognite-sdk-python.readthedocs-hosted.com/en/latest/data_modeling.html#cognite.client.data_classes.data_modeling.instances.Edge
Andre Alves
Forum|alt.badge.img+13
  • MVP
  • 147 replies
  • July 4, 2024
Hi @Erik Wiker!
    for edge in edges:
Hi @Erik Wiker,
We are following up to see whether you're satisfied with the responses you've received?
This answer seems out of date. `client.relationships.list(target=instance_id)` does not have the `target` argument. I can use `target_external_ids`, but that still gives me nothing (empty response).
Moreover,  `client.edges.list(target=instance_id)` does not exist altogether.
I think the world has moved on to `client.data_modeling`. Can you show how to do this using `client.data_modeling.instances.list` apis?
