Cognite Function - throwing Time our Error
  • August 23, 2022
  • 77 views
Cognite Function throwing Time out error.
Function ID : 4525036003390684
This was working fine couple of hours back.
Best answer by Ivar Stangeby
Could you also please trigger 4525036003390684 again from the UI, or create a schedule on it?
This topic has been closed for replies.
  • August 23, 2022
Hello!
Could you also provide the CDF project name?
Was function 4525036003390684 working fine a couple of hours ago, or a different function?
yes it was working fine before.
CDF Project Name : Celanese
  • August 23, 2022
Thanks! I’ll see if I can find any indication of what is wrong.
By chance, does the function response / function logs give you any insights?
No , function logs gives insights only if it was success.
As it is a time out, it’s not showing any insights
  • August 23, 2022
