File format require for P&ID and 3D model
  1. What are the permissible size of file can upload in CDF ?
  2. Which type of P&ID files are directly read in CDF ?
  3. Which type of 3D Model files are directly read in CDF ?
  4. Is any converter tool is available in CDF for conversion of file in to require file format for P&ID and 3D model in cognite data fusion ?
We have documented the supported file formats for 3D models and limitations here. By uploading your models via the UI, a processing of the files will start automatically and the models are ready to be viewed once the processing is done.
We also support setting up extractors for 12 different formats, see screen for supported source systems.
I hope this was helpful for the 3D part of your question.
Ragnhild
got it. thanks for the information.
Another question is for PID as only PDF file we can upload for P&ID, or any other file will support by CDF?
