How to load CSV files with DB-Extractor
Hi, everyone
I'm trying to load a CSV file using db-extractor. This is the configuration I'm placing in the .yaml file :
but I'm encountering the following error:
It seems that the error might be that the query section doesn't recognize the sheet name. I checked that the sheet name matches by opening the file in Excel format, but the error persists. I also loaded the same file in .xlsx format and it loaded without any problem.
How should I specify in the query so that it takes the correct name in CSV format?
Karina Saylema
@Aditya Kotiyal  @HanishSharma  @Jason Dressel  @Jairo Salaya @Liliana Sierra
Best answer by Rogerio Júnior
Hi Karina,
Here is the example query to use with .csv files:
  - name: query_csv_test_local
    database: csv_test_local
    sheet: file
    query: >
      SELECT
      FROM
        file
“sheet” must be set to “file”, and your query must point to “file” as the table as well.
Best Regards,
Rogerio Junior
Cognite Engineering
Hi Karina,
    sheet: file
    query: >
      SELECT
      FROM
        file
Best Regards,
Rogerio Junior
Cognite Engineering
It worked great, thank you very much @Rogerio Júnior
