Transformation SQL code to github
  • February 23, 2024
  • 26 views
In Data management / Integrate / Transform Data you can create and edit SQL code to transform your data.
Is it possible to backup/synchronize those code with github?
I am thinking about possible proliferation and duplication of many transformation pipelines, repeated code snippets, have to correct /update the same code in multiple transformations.
Best answer by greger
Yes, the recently released beta9 introduces support for pulling down transformations after making changes to it through the UI:
cdf-tk pull transformation --help
It is documented here.
greger
  • February 24, 2024
