Cognite Custom Extractor Util Config
  • February 13, 2024
  • 7 replies
  • 86 views
How can we use hybrid configs (local and remote) in custom extractor utils?
Edit: while trying to consume combination of local and remote configs (published in extraction pipeline mentioned in local config), it just loads local configs.
example configs:
type: local
cognite:
    extraction_pipeline:
        external_id: extraction-pipeline-id
custom:
    property1: some-value
type: remote
custom:
    property2: some-value
Best answer by Murad Sæter
No, that is not a supported use case.
If you need different values per extractor-machine locally you could use environment variables in the config stored in the extraction pipeline.
Murad Sæter
  • February 13, 2024
It’s same as with the Cognite relased extractors. You have a local file with type:remote which refers to the extraction pipeline which contains the config.
Sample local config:
type: remote
cognite:
    # Read these from environment variables
    host: ${COGNITE_BASE_URL}
    project: ${COGNITE_PROJECT}
    idp-authentication:
        token-url: ${COGNITE_TOKEN_URL}
        client-id: ${COGNITE_CLIENT_ID}
        secret: ${COGNITE_CLIENT_SECRET}
        scopes:
            - ${COGNITE_BASE_URL}/.default
    extraction-pipeline:
        external-id: ${COGNITE_EXTRACTION_PIPELINE}
  • February 14, 2024
@Murad Sæter I’ve added more details in post, is the expectation valid from remote and local configs?
Murad Sæter
  • February 14, 2024
What are you trying to achieve here? You cannot have local and remote in the same config.
If you have a local config with the extractor it will only read the local config file.
If you have type:remote with the extractor it should only contain details around connecting to CDF (cognite section). The extractor will then connect to CDF and read all config from the extraction pipeline.
  • February 14, 2024
I want to merge custom config entries from local config and remote
I understand that ‘type: remote’ allows only ‘cognite:’ configs from host and rest from extraction pipeline. Is there a way to get custom config-entries from local config file?
host config file:
type: remote
cognite:
custom:
config in extraction pipeline:
custom:
Murad Sæter
  • February 14, 2024
  • February 14, 2024
Thank @Murad Sæter
type: remote cognite:     # Read these from environment variables     host: ${COGNITE_BASE_URL}     project: ${COGNITE_PROJECT}
    idp-authentication:         token-url: ${COGNITE_TOKEN_URL}
        client-id: ${COGNITE_CLIENT_ID}         secret: ${COGNITE_CLIENT_SECRET}         scopes:             - ${COGNITE_BASE_URL}/.default
    extraction-pipeline:         external-id: ${COGNITE_EXTRACTION_PIPELINE}
Im wondering with this approach, where does the actual variables value ${} is stored?
Thank you
